87 r10 engine and trans problems
Torqueshop1
Iowa
Dillon
R10
Went to check fuel pressure today and this brown fluid scrap was on back side of my throttle body
Torqueshop1
Iowa
Dillon
R10
Pic
Torqueshop1
Iowa
Dillon
R10
Fuel pressure is 11 psi at idle. But when u first turn the key and let the pump cycle it is less then 5 psi
Torqueshop1
Iowa
Dillon
R10
Blown head gasket is desppiting that sludge on the back of my throttle body via the valve cover vent tube that flows into the tb spacer. I've been keeping an eye on it and that sludge dries up after about 1.5 hrs. I had the truck warmed up and the tb spacer off and haven't had the starting issue
yevgenievich
Place
Name
Year
Model
Size
And sounds pump is weak or there is restriction. Tbi should have 11-14psi. But the sludge is a problem too.
Torqueshop1
Iowa
Dillon
R10
New distributor, Ignition control module, pickup coil, cap, rotor, plugs, wires, ignition coil, rebuilt throttle body, fuel pump relay, new manifold temp sensor and coolant temp sensor. Head gasket isn't blown. Still having the issue.
Fuel flows through injectors perfectly also
yevgenievich
Place
Name
Year
Model
Size
Where was the sludge coming from. Have you verified the fuel pressure to be above 10psi during cranking no start scenario? Might need to connect a compiter to it.
Torqueshop1
Iowa
Dillon
R10
Valve cover breather. I put a push on filter on it sludge was probably being created from condensation from short trips. Oil and coolant r fine.
What is the fuel pressure suppose to be with key on and engine not running, just the pump doing the initial cycle
yevgenievich
Place
Name
Year
Model
Size
It should get up to 11-14 psi and stay there during cranking. If it is dropping down while cranking it could be an issue. Or can just check fuel pressure when cold when it starts right away and then check when warm during the problem. If they are similar, then not a problem. Would likely need to get a computer connected to check what ecm is seeing.
Torqueshop1
Iowa
Dillon
R10
Also I checked out my oil pressure unit and it only has one wire. I was under the impression that a tbi oil pressure unit has two wires and one of them is for the fuel pump?
Torqueshop1
Iowa
Dillon
R10
The p.o. put an aux oil pressure gauge in the truck that has a small clear tube running to the other port behind the distributor. Could this be the issue if the truck doesn't fire up right away and there is no secondary oil pressure circuit telling the pump to run? If so how do I go about fixing it I don't see any cut wires or un used plugs
Tobe's84Jimmy
Seattle
Tobe
Jimmy Sierra Classic
hello all. dont really know how the setup is for tbi trucks, but maybe the kickdown cable for your trans needs adjusting(?) mine works in conjuction with the throttle cable ( carb'd ) and if its off the trans will not shift right. also, might be your torque converter is worn out (?). as far as the motor issues, someone mentioned goin back over the basics, always a good idea. my only other thought would be bad O2 sensors(?) hope you get it sorted out, good luck
87ChevyR10
Kansas
NA
NA
NA
Mine is a single wire and I do not have an aftermarket gauge installed. Actually, the plastic around the connector broke off, so I can't use it right now anyways. But, it never has worked. Gauge is always maxed out.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Your sensor or gauge is shorted to ground
87ChevyR10
Kansas
NA
NA
NA
It's gotta be the gauge, cause the sensor is disconnected. I can find the wire under the truck, but not above. Makes it tough to trace.
jrcubby
