86 c10 Gen6 454 almost ready to fire. What wire and connectors are these to?? Video and pic's inside :)
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
There are more videos on this on my channel. If your not sure whats going on, here a video.
here are some pic's
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Ok, im doing the wiring now and need to know what these wires are for. I got one thats a pink wire with a black stripe, one tan with a single blade connector, another with 2 blue and 1 tan dual blade connector, then a blue or baby blue wire someone cut and added a yellow wire for length i guess with a female blade connector. Other than that I think I can figure the rest out. Thanks
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Tan wire, maybe oil pressure sensor. The single blue, could it be faded green? Temp sender. That wire would see lots of heat since the temp sensor is usually in the head near the exhaust. That would also explain the necessary repair.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Blue could be the electric choke.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Thank you Turbo!!
kevin700
