bbgbouncer
- Feb 21, 2022
- Utah
- Joe
- k1500
Thanks for any help here. I looked through past threads and didnt find what I needed.
Situation 85 k1500 with 305. Runs like a champ. stock setup. My 15yr old daughter just bought this. It is covered in oil. We start replacing the valve cover gaskets. I get to looking at all the smog items, vacuum lines, smog pump. I says to myself "we dont need all this garbage". rip it off.
Now it wont idle. it starts fine. I have turned up the idle screw (in effort to solve the issue) now it revs high on start. then drops to what should be idle and dies. you can keep it going a a high idle (sorry no tach) but if you try to let is low idle it tries to die. I have to pump/feather the pedal to keep it going.
I have plugged up all the vacuum ports. hooked the vacuum assist on the distributor to a vacuum port behind the carb in the intake manifold.
It does look like a Qjet. any thoughts?
