84 K10 Tie Rod
MtBraun
South Dakota
Strangely having a heckuva time getting a tie rod setup to work on this truck. I tried the heavy duty ORD tie rod, and I can't get close to full steer without diff cover contact. I do have the Ruff Stuff diff cover which is a bit thicker than stock, but its very clear the ORD rod is too thick. Tried a stock one and still have toe out with no more inward adjustment. I can't find the packaging for the stock tie rod, but think I bought it off LMC a while back. The stock rod is 1 1/8" in the main body. I have converted this over to cross over steer so just looking for a solid tie rod that will work on this setup.
Help is appreciated, thank you.
dabsRus420
