84 GMC C2500 Dies After It Warms Up
Snoots
Roger
Jimmy Sierra
350 w/203
I've also know ignition coils to cause this.
68post
very, VERY, limited access member
Indianapolis
Tim
84 K30 SRW Silverado, 85 C20 C6P
454, TBD
Exactly !!
I have had it happen to me. Any application that has the divorced coil on the rear of the intake and in front of the distributor is susceptible.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Break the fuel system in half. Feed the pump out of a fuel can and see if the issue repeats itself. Vapor lock is a hard sell at 70*. What’s your carburetor situation?
+1
You aren't going far or long enough to promote vapor lock. You need to determine if you have spark and fuel when it happens.
Eliminating the tank and lines to the pump is a good first start.
Big Chip
Michigan
Kevin
C35
When it was hot out my truck would stumble and stall within a few miles. The fuel system was a bit of a cobbled mess though once it got into the engine compartment. I think the OP cut out because he didn’t have a definitive answer though. Time will tell I guess.
Domarinolo
