83 K20 GEAR RATIO
Old60Driver
1983 K20 Silverado
Houston
Michael
K20 Silverado
G'mornin y'all!
So, after some calculatin' this morning, I'm pretty sure I have 4.56 gears in her. Going out to confirm later this morning, but it's just too danged cold right now. I'm 99% sure the original owner (late father in law), never had anything modified on the truck, but it was used as a farm truck (hauling horses, trailers, etc..), so maybe he did for the extra low end grunt? I didn't even know that 4.56 gears were an option for a 350 K20 stock
Anyway, I very rarely get on the highway, but when I did yesterday, I noted the following:
60 mph (gps confirmed)
2950-ish rpm (digital)
285/75 R16 tires (32.83" tall tires)
That led me down another rabbit hole looking at gear ratios. I couldn't believe how much of a difference the gear ratio could make! It sounds like I could reduce my highway RPM @ 60 mph by 500 or so by going to 3.73's. Does that sound right? And if so, how much of a hit will I take on the 'around the town' cruising performance? She runs great, and I can bark them if I'm feeling frisky. And the roads are wet. LOL
I don't do any towing with her, but dang that highway RPM is insane so I'm thinking of making the swap.
Thoughts y'all?
Based on my references, the 4.56 was only a factory option for the K30, and 4.10 was the lowest ratio for a K20. However, it may have been swapped.
WebMonkey
Missouri Ozarks
my 85 k20 ultra hd has 3.73 with stock height tires.
i think it's a pretty sweet spot for off the line vs 60mph state highways.
'monkey
SquareRoot
Excellent gears! The issue is the 3 speed transmission. Put an overdrive in it and start living the dream.
Buck69
Northern British Columbia
D30 CUCV
6.2 (removed)
I have the 4.56 gears in mine. It is my understanding the carrier also requires changing if going to 3.73's. Something to include in your thoughts if you haven't.
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
I agree, the transmission is the problem, I would install a transmission with an overdrive and keep the 4.56 gear ratio. I just did an LS swap and installed a 4L60E transmission into my 73 Blazer. The Blazer has 3.07 gears which were way too tall for the new transmission. I am spending $4100 to have 4.56 gear ratio installed front and rear.
Auburn, Washington
According to the vehicle info kit with all the options, 4.56s were available in 80s K20s.
Plus I recall having one, back in the day. Was an 81 or 82. Base model K20, 350 and 4.56s. Not swapped.
aaron hunsberger
