Boone83K10
- Feb 4, 2013
- Boone, NC
- Benjamin
- K10
This past spring I swapped in rebuilt 10 bolt axles with 4.56 gears. Almost everything is new. The only things I didn't buy new were inner/outer front axles, rear axles, front hub assembly and spindles. I picked the two best inner axle/outer axle and rear axles from my truck and swap axles and used two best spindles. One spindle out of 4 was trashed, the threads were stripped.
I have noticed some wobble when driving. I attributed it to needing new tires and a professional alignment ( did a good redneck driveway alignment and it drives perfectly straight). I have only put 500 miles on it since I did the swap.
I decided to check the bearings. My front tires have play at 12 and 6, none at 9 and 3.
I took off the hub and the inner bearing inside surface and the spindle where it rides is blackened. Almost looks overheated. There was absolutely no noise from anywhere on the truck.
I will get pictures. I did everything to spec according the FSM I have. The only thing that was NOT spec'd was the outer lock nut. 205 ft lbs just sound ridiculous and I wonder if that is why one spindle has stripped threads.
Any body help me out. I am not sure what went wrong.
