81-87 bed bolt location diagram
dusterdude
US
mark
gmc c15
Does anyone know of a diagram for installing the bed bolts?i was hoping i didnt have to hunt and peck my way through it.thanks
ali_c20
Austria
Alexander
C20, K5
I hope that's what you're looking for.
Keith Seymore
Motor City
Keith Seymore
4.3L
Unless you are absolutely fanatical about duplicating the factory build it kinda doesn't matter. You could use all short bolts.
The only reason they mixed and matched in the factory was to give easy access around the fuel tank or crossmember clamshell brackets to the guy in the pit tightening them down. He was doing 8 bed bolts every 45 seconds (60 jobs per hour) - plus hanging the spare tire - so he had to be quick.
I don't recall for sure but I imagine there could have been some variation between long vs short, 2wd vs 4wd, half/three quarter/one ton, single vs dual tank, and exhaust routing too, based on the above.
On my '87 short box I believe both LH and RH in the #2 location were long.
K
Keith Seymore
Motor City
Keith Seymore
4.3L
You could also look at your frame to see if there are any "sleeves" remaining.
Any location that got a long bolt had a metal pipe between the upper flange and the lower flange of the side rail, so that the attachment could compress and hit torque.
K
Dravec
Ft. Worth, TX
Monte
R1500
Not gonna lie. I would really like to do my '87 as a close and correct to factory as possible.
armchair
