80 Sterring box fitting
sticman
Langley BC Canada
Jason
K10 / V10
350 5.7L TPI
I seem to recall that the steering box in 80 trucks may have had oddball fittings.
I did a double take when i looked at the box fitting and the metric 18 o-ring to 6an fitting that you are supposed to use on 80 and up steering boxes. All my other o-ring style fittings have tones of open depth.
measurements are so tight that i don't want to crush the floating ball / screen.
Can anybody confirm if the picture of the high pressure port is different on newer steering boxes?
I don't know but I am here to learn :popcorn:
mb84c10
Maine
Mark
Pre 80 is standard flare fitting end 80 and newer is 18mm which is same as any new style box.. i used all 98 s10 steering pump and lines on mine to convert to type 2 pump..
mb84c10
Maine
Mark
the saginaw boxes havnt changed
wolfdog63
