8" Lift Questions
conny8412
WNY
Aaron
Swapping my 87 k10 body onto a new powdercoated shortbox frame with 1 ton axles. On my current truck with the 1/2ton frame/body, im running a 12" superlift with 39.5 boggers. The new frame im moving the body to has an 8" all spring superlift. I am trying to find as many pictures as possibly to see what i can fit under the 8" without trimming. I have googled my heart out and searched on the forum without much luck. This truck will strictly be a mall crawler/show truck. No wheeling whatsoever. Preference would be 38's or 38.5's but i wanted to see pics of that setup and confirm it would work.
Thanks in advance!
marks86
Latham, NY
Mark
12v Cummins
I have seven inch suspension with a one inch body lift up front and I clear 37s but they rub on the fenders at full crank off road
conny8412
WNY
Aaron
Ya, I've heard mixed things. This truck won't see offroad, it'll strictly be a show truck/weekend driver.
I really don't want to put on a another body lift. My new 8" is all springs. I've seen some other options like diy4x EZ inch; does that only move the axles forward or does that really give you an extra inch of lift/clearance? I think at 9" I could clear 38's pretty well. Let me know of there are any body lift alternatives to gain 1/2" of additional lift.
Thanks again guys
The EZ Inch does get you another inch of height. You can have the axle centered, or choose to move it 1 or 1.5 inches forward or rearward.
conny8412
WNY
Aaron
How hard is the install for the EZ inch?
hirschdalechevy
norcal
rich
k-30
Simple , all I did is grab some solid 1" blocks and longer center pins and u-bolts and throw it all together and you have a 9" lift. Make sure you check out all your other stuff , driveshafts , shocks , brake lines etc... and make sure they are good to go.As far as running 38's that all depends on how wide your wheels are , 8" wide no problem , 10" wide still problably ok , 12" wide maybe some trimming , 14" wide trimming for sure.This is my blazer I am working on with a 9 and 40's just for mud and it is fine , but for rock crawling no good , on the street it barely touches but the fenders are cut.
hirschdalechevy
norcal
rich
k-30
Here it is with 38" dick cepeck's and less lift with 10" wide wheels , no rub at all
conny8412
WNY
Aaron
Thanks man! How wide are the wheels with the 40's?
hirschdalechevy
norcal
rich
k-30
They are bart 15x14 , 8 lug , 3 1/2" back space
EEEZNOW
Birmingham, AL
D
That bumper looks really good! What is it?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
6'' suspension 3'' body lift 38x12.50 tires
I had to twist it pretty hard to get the tires to rub they were only 12.50's on 9.75 wide wheels so not real wide
for a pavement pounder I think you could clear 38.s
Turd427
Red rock, AZ
Kyle
I had a 78 k5 with and 8" lift and 1" shackles up front with 38s and no rub. Tires looked small on it. Kinda like a 6" lift with 35s. I'll see if I can find any pics and post them up.
bglendon
