I’m going to tweak on the timing a little bit and see if I can get it right. Right now it’s just by ear, pulled number one plug and cranked until compression stroke and and went from there. Truck originally just backfired out of the carb after I put a quadrajet on it so the timing was way off, it’s now got an edelbrock 1405 4 barrel. I need to get the timing set at the sweet spot and start tuning the carb and sell the truck.
Is your distributor stabbed 180 degrees out. CAN it get started? Also, do you have a manual choke hooked up to that(1405 is a manual choke, i think?)
also it sat for 10 years, pull your valve covers and turn it over with spark plugs pulled and fuel unhooked. I have a feeling you possibly are looking at a situation thats common from sitting where a valve or three (whos counting anyway) is sticking and youre getting something from an exhaust valve sticking open or something. Likewise, your distributor being stabbed right is important.
And is this distributor new or is it original?
this is a pre-HEI distributor but the important part is the top. seee the two weights? They kick out. When turning faster, they go out farther the springs keep them in to a set amount. Then they are supposed to glide back to rest when not spinning. they get dirty, rusty, and stay kicked out, that would advance your timing potentially at random if not resist coming back down after spinning up causing weird issues. check em.
