75gmck25
- Oct 13, 2016
- Northern Virginia
- Bruce
- K25 Camper Special TH350 NP203
I purchased a set of poly bushings for the springs on my '75 GMC and have started with the front bushing for the front springs. Truck is jacked up by the frame and the wheel on that side is hanging about an inch off the ground. I have a jack under the axle housing to take tension off the spring.
- Got the nut loosened up without any problem
- Tried turning the bolt to see if it would thread and come out of the bushing. I can turn it slowly with a breaker bar, but it never frees up and turns smoothly. I tried my impact wrench on it and the rubber seems to absorb the impact, since the bolt does not turn. I don't know if a stock bushing has a metal sleeve around the bolt, but I don't think so.
- Put the nut back on and started smacking on that end with a small sledge hammer, but so far it is not moving. The rubber bushing is probably stuck to the bolt and is taking the impact.
Now I'm looking at options.
1 - Use a sawzall and cut the bolt where you can see it inside the upper mounting bracket. However, then I need to find new bolts. LMC truck has them, but they are slow to ship and relatively expensive. It looks like its a 9/16" grade 8 bolt about 4 1/2 to 5" long.
2 - Try using a ball joint removal tool to press the bolt out. This might work, but I'm not positive the kit will have the right pieces to get the leverage needed.
3 - Burn the rubber bushing out with a torch. This will be messy and smoky, and I will have rubber residue burned onto everything. Also, the burned rubber might just make everything stick together even more. However, it might work.
I've also included a couple of pictures.
I appreciate any suggestions you might have.
Thanks,
Bruce
Thanks,
Bruce
