74 k10 clutch job
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
Long time no see fellas! I recently bought a house and needed a truck to move so I snagged a 74 k10 with sm465. Its been great but all of a sudden the clutch is stuck engaged when I go to park it one day. Feels like I lost connection to the pressure plate, all I feel through the clutch pedal is the return spring now.
I assume its time for a new clutch and that something failed (throwout bearing?). The clutch itself was starting to get weak before this problem. I was curious what method is easiest for the earier manual k10s between dropping the trans, lifting the engine, or lifting both the engine and trans in order to do a clutch job? Pic for attention, hoping to be more active here its been a while :birgits_tiredcoffee
Hey dude, I remember you! Welcome back!
Have you checked to make sure the clutch linkage is still all hooked up? With a lot of years and use, it can literally fall apart or even wear an end right off of a rod.
74Blaze
Nashville, IN
Gerald
K5/Blazer
I'm not sure which method is easiest, but when I put the clutch in Blaze, I dropped the Transmission and Transfer Case together using a Transmission Jack. It wasn't too bad of a job.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
How difficult was it so slide everything together afterwards? Totally different animal, but when I did the clutch in my fiero I had to drop the cradle and pull everything apart. I ended up trying to slide the transaxle onto the engine while on an engine lift. It was kindof a pain to align everything and slide together without putting torque on the clutch.
Howdy, ever get those LEDs in? :wave:
I've checked what I can with one person, need to drag my brother over to help out.
Any recommendations for a heavy duty clutch? I work and play a lot with the truck so it does get abused, plus may do a crate engine swap someday budget permitting
SquareRoot
I put a new McCloud clutch in my 85 about a year ago. Been very happy with the quality. I'm actually pulling the trans/t-case out this weekend to swap a new 4500 for the current one and swap t-cases from a 208 to a 205.I have been contemplating putting them in as one unit or two as well. Given the weight (#350) I'm pretty sure it will be a two-step process.
74Blaze
Nashville, IN
Gerald
K5/Blazer
I remember a lot of shaking and pushing (like five or ten minutes), then it just slipped in to place.
fast 99
Spokane, Washington
When it's installed check the cab for movement front to back when clutch pedal is depressed. If it has original cab mounts they are very likely shot. Have seen cabs move 1" or more. Really messes with clutch adjustment.
On my 75k I'd pull the engine. IMHO on my old K I can pull the engine quicker and easier than the transfer case and transmission.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
I think both methods are pretty easy on the removal, what I worry about is ease of alignment. Had any issues on the reinstall before?
I wouldn't bet a dime thats not the issue... :rofl:
@guitarfreak235 I'm sorry man I did my first engine swap,no adult supervision or assistance at 14, quit having alignment problems at 15,that was my first automatic to manual swap and I didn't line the clutch disc up correctly. If you've done an engine or transmission once or twice you won't have a problem. Cut the heads off a couple of long bolts,cut screw driver slots in them,use them as longer alignment dowels in the lower 2 bolt holes.
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Line up bolts,, bit of oil on input shaft,, good eye to make sure things are going in square and life is easy..
Turbo4whl
Downingtown, PA
Wayne
Jimmy
As stated, very important to have the clutch disc centered. Use an alignment tool when bolting the pressure plate on. The course splines of the input shaft go in easy if lined up. What can help, is shift the trans in gear before removing the shifter. Then you can turn the input shaft with the tail shaft.
When the clutch fails on and the pedal has no push back, most likely the pressure plate has a broken finger. Never buy a (rebuilt) pressure plate.
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
I have seen the linkage rod push right threw the throw out arm before
Yep, me too. When you think about how many times a year the clutch gets used, it actually amazes me that the parts last as long as they do.
fast 99
Spokane, Washington
LUK clutches are good for stock applications. Diaphragm style is very smooth if available. Never had an issue that I could say was caused by that brand clutch.
Nuggets40
