Greensweets
- Oct 8, 2016
- Ceres
- Nick
- C10
Hey guys ok when I lowered my 74 I used cpp 2.5 spindles and mcgaughys 2" drop springs well I have still a 275-75-15 tire up front so when I took it off the stands,the truck sat so low the fender tubs sat on the tires and couldn't roll. So I took my stock springs and cut a half coil and installed back in and it sits great with the tall tires,that was temporary,now I just got in my mcgaughys 1" drop springs which are the same length just stiffer spring steel I guess. My concern is before I put these new stiffer springs in is it gunna drop down so low again it's gunna sit on the tires? Now the front tires will be 235/60-15 soon but I mean for now? Has anyone used this same set up from cpp and mcgaughys and had this same issue?
