73 k5 power window conversion
Troyesco
Bay Area ca
Troy
I want to convert my door manual windows to power. If I get regulators from a 76 blazer will they just bolt right up or is there more needed?
gmachinz
Harnessworx Inc
Iowa
Jabin
1973-76 doors are all the same. Obviously you’ll need a harness but the door hardware should directly replace your manual parts.
350 w/203
Yup.
Get the ENTIRE harness for both doors
Get the boots
Get the shims (if any) AND MARK EACH DOOR HINGE BOLT FROM WHERE YOU TOOK THEM! Do this for your old doors as well.
AND while you're at it get the latch pin from the door frames.
Don't throw anything away from your old doors.
Troyesco
Bay Area ca
Troy
Yup.
Get the boots
Thank you.
RoryH19
Rory
R10 Silverado SWB
You may as well get the power locks and harness while there if you don't have it already.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Correct me if im wrong but i dont think 73-76 came with power from the factory. Your 76 donor might have later model doors on it? I do believe the guts will swap between the two. but the door panels don't.
Troyesco
Bay Area ca
Troy
Actually someone is just selling the regulators alone no hardware so I’ll have to try and make them work. I can’t seem to find any aftermarket regulator kit for 73-76.
Troyesco
Bay Area ca
Troy
That must be why I can’t even find aftermarket power window regulators either for 73-76
Right, no power windows offered before '77. The inner door stamping is a little different to accommodate the power window regulator.
Troyesco
Bay Area ca
Troy
So if I get a power window regulator it won’t just mount in the original manual spot?
I don't believe so. But I've never tried it myself.
RoryH19
Rory
R10 Silverado SWB
@bucket you reminded me that I remember reading that power windows started in 77. Could he install 77+ doors if he really wants power?
73c20jim
Tombstone, AZ
Also I believe the 73 had small wheels on the mechanism to match the window mount at the bottom of the window.
This changed to larger wheels and corresponding window mount in 1974-up.
Troyesco
Bay Area ca
Troy
Anyone install a universal power window kit in a 73?
ExtraZ
