700R4 that only mildly backs up at 1200 rpm
Gilmore
Eureka
Christopher
6.2L Diesel
Ok I have a 1984 chevy K10 w/350 HO and a TCI Maximizer 700r4. The issue I have is that this is a new transmission and it goes forward like a freight train but backing up is a problem. When I shift into drive with my foot off the brake the truck moves. When I shift the truck in reverse however nothing until I hit 1200 RPMs and even then it’s anemic at best. Any help or good questions are appreciated!
Link to Trans: https://www.jegs.com/i/TCI/890/3714...=Transactional&utm_content=Order+Confirmation
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Sounds like a plugged flow port, drop filter and check valve ports - may be assembled with debris.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
If it’s a new transmission, I wouldn’t do anything until you talk to TCI. Make absolutely sure you have followed their installation instructions to the letter before calling them.
I’d be curious to know what they say.
Gilmore
Eureka
Christopher
6.2L Diesel
TCI just tells me I have too much fluid, the trans only take 6qts. I emptied the trans and put back in exactly 6 qts and the same behavior.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Find a gauge that reads to 300 psi, put it in the line pressure tap about the manual linkage. See what the pressure is in reverse.
It isn’t normal to need to rev the engine to back up.
Have you driven it yet? If so, get it up to 30mph, put the shifter in 1st, see if it has engine braking. If not, the low/reverse clutch pack is suspect. If it does, the reverse input clutch is the problem.
Gilmore
Eureka
Christopher
6.2L Diesel
Apparently I need to flush the trans and torque converter because you can’t use full synthetic fluid in a TH350, 400 or 700R4 it needs to be petroleum based Dex3.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Yes I use valvoline max life in red bottle at Walmart for cheaper price.
Gilmore
Eureka
Christopher
6.2L Diesel
Yeah I did too but that is full synthetic and apparently is too thin once the trans is warm to allow the reverse clutch to engage.
Thats a full synthetic Dex VI equivalent. It meets the Dex III spec also, but is slightly thinner than the standard blue bottle Valvoline ATF
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
There is a bleed hole in the reverse input clutch piston, from the factory the hole is a little too big. TransGo include a tiny freeze plug with a very small orifice that make the bleed hole smaller. You can buy the freeze plugs from TransStar and other venders.
Put a pressure gauge on it. TCI lists line pressure specs for each model transmission. Assuming the pump is good, the transmission was built correctly, and the cable is installed and adjusted properly, synthetic fluid isn’t your problem. If TCI is telling you otherwise, it sounds to me like they are backpedaling.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Gilmore
Eureka
Christopher
6.2L Diesel
Well it’s going to cost me $200 to get the transmission and torque converter flushed so I hope your wrong and this works. ;)
Gilmore
Eureka
Christopher
6.2L Diesel
Well you weren’t wrong, the flush didn’t work now I’m talking to the warranty manager.
Carb'ed Vortec 350
Carb'ed Vortec 350
Are you arguing with yourself?...lol...
  • Like
Reactions: WFO
Doug Hampton
