Splandman
- Jan 1, 2014
- Crescent, OK
- Scott
- K10
I haven't been on here in quite a while. My truck went through quite a few changes, most for the better, but I have been through either 4 or 5 700r4 rebuilds in about 2 years.
Here is my current setup.
383 making about 450hp/450 ft. lbs, NP208, 4.10 gears, 33's, 700r4. Last night the 700r4 had a failure at about 65 mph and lost all its fluid, I left the truck at a gas station until I can figure out how to get it home. Couldn't really tell what failed because the whole under side of the truck was drenched.
The transmission is still under warranty, it has maybe 1500-2000 miles on it, but I have had it back in this shop so many times that I think I'm just done with them. Some of the failures have been their fault, two of them were other shops fault. Not really sure on this one yet.
My question is can I trust a 700r4 with my set up for a daily driver? I do not go mudding, I do get on it almost every time I drive it, but I'm not roasting the tires or anything....except on dirt roads. I know a lot of people run this transmission that make more power than I do. I also know a lot of people hate it. I have to have an overdrive. When I'm running 65 mph right now I am right at 2k rpm and I like that. I drive on highways quite a bit.
Some people have said I should get a 4L80E in there, not sure about adapters for the 208 to 4L80E and don't have the cash to get a new transfer case.
