7 or 8
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I haven't removed the light switch yet, can someone tell me if the light switch for a 73 C10 is a 7 or 8 terminal? I'm finding both.
73c20jim
Tombstone, AZ
What is your wiring harness???
:patriot::patriot:
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
It's a standard truck with gauges. No AC. I converted the truck from a 6 cylinder manual to a V8 with AT.
marks86
Latham, NY
Mark
12v Cummins
I bet you would have better luck googling a wiring diagram for a 73 c10
chengny
The P/N for that switch is 1995216 (GM) or D1505A (Delco).
It has 7 male terminal tabs.
The wiring harness will have 8 sockets but only 6 wires coming in - the 2 sockets shown below will be empty
Terminal 3 (black circle) is jumped to 5 and was reserved for an additional lighting circuit, but was not used. Terminal 7 would be where shown by the yellow circle. But if your switch is original, there won't even be a terminal 7.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Great info. I'll be taking the old one out before I buy another one.
bglendon
