6 inch lifted 1973 truck back to stock/how to do it?
JACK34
Banned
OTR TRUCKER
JACK
I recently purchased a 1973 half ton 4wd that has a 6 inch spring lift. I want to bring it back down to normal what all do I need to do? The owner is trying to find a steering arm and I'm trying to find springs. LMC does not stock the rear 1973 1/2 ton springs but does stock 1973 3/4 ton springs. Front springs LMC has. Can I use the 3/4 ton springs and will they fit? Any help would be appreciated. Thank you.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
What length are the existing rear springs in the truck? Do the rear spring brackets appear to be in the original location (riveted on vs bolted or welded)?
You can get rear springs for your truck from any number of other online vendors. None of them are going to be NOS, unless stated otherwise.
WFO
Texas Panhandle
I'd check with junkyards, or go to a local Spring Shop.
JACK34
Banned
OTR TRUCKER
JACK
Yes mounts are stock.
JACK34
Banned
OTR TRUCKER
JACK
I think I got her figured out thanks for all your help much appreciated.
JACK34
Banned
OTR TRUCKER
JACK
One more thing. When I put it back to it's stock height does anyone have an idea on how big of tire I can go with? I'm looking at 30x9.50 15 or maybe a 31x10.50. But I don't know what will fit until I try it. The rims I have on my 94 are 15x7 Back spaced 3.75 offset -6MM bolt pattern 5x5.00. Not sure if that will match up to the 73. Any help would be appreciated. Thank you.
mcarlo86
ND
Suburban
31X10.50 15's will clear just fine at stock height.
unimogguy
