6 inch lift
nicdanger1911
The Colony TX
Nicholas
Took my 6 inch lift off, and now can't find a stock steering arm. Any suggestions on where to find one! Not many k10s in the pick-n-pulls!
Skweegle89
Oklahoma
There is a sticky on here about using the old jeep Cherokee shafts. They bolt right on and are generally easy to find. They are beefier than the stick shaft and let's you get rid of that rag joint that always seems to fall apart.
firebane
Calgary, AB
Curtis
He's looking for steering arm.. not steering shaft.
To be honest for the cost of the arm just buy a new one.
nicdanger1911
The Colony TX
Nicholas
Would that be a dealer item? Can't find one online, lots of steering arms for lifted trucks but nothing for stock!
Skweegle89
Oklahoma
Whoops
MadOgre
NA
NA
NA
NA
NA
The pitman arm attaches to the steering gear, the drag link is the 2 ball joints that connect the pitman arm to the steering arm, which is attached to the steering knuckle/axle.
MadOgre
NA
NA
NA
NA
NA
Unlikely that any dealer will have that part. As far as I know pretty much everything aside from some useless stuff like horns and light bulbs are discontinued for our old squares.
Junk yard is our dealer supply now
DanMcG
Central NY
k10 k10
Try Rock Auto.com
nicdanger1911
The Colony TX
Nicholas
That being said, anyone interested in the 6 inch lift I removed? All you would need are shocks, u bolts and brake lines and those should be new anyways!
Skweegle89
Oklahoma
what brand is it and what are you looking to get out of it? rear springs or blocks?
350runner
tx
Ceasar
Man I'm right down the street from you... Josey ring a bell? To bad it's for a 4wd I'd snatch it up
nicdanger1911
The Colony TX
Nicholas
Skyjacker 6 inch lift, front springs,rear blocks, sway bar brackets, steering arm and some new bushings. $250 Obo.
nicdanger1911
The Colony TX
Nicholas
Thanks, wish I had seen that yesterday! Found a guy on eBay selling like 50 stock steering arms so I snagged one!
Nuggets40
