Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
It does have a hefty trans cooler already. I do think electric fans in addition to the big clutch fan and an engine oil cooler would probably help a lot. An 8.1 would be a cool swap too. Having modern fuel injection and a 4L80E would be sweet.
Realistically, warming up the 454 (heads, headers, flat top pistons), cooling upgrades and a 4L80E would probably be most cost effective and would be a lot of fun too.
For that payload you're pulling, does the trans cooler have a fan too?
I will say, an oil cooler did make a difference in idling on my 502. (I bring up the 502 alot, but it's a large motor, and makes alot of heat)
Went from 220 to 208 just sitting still running.
Every bit of heat extraction from the motor helps.
What sort of radiator are you running? A big beefy 4 core might cool her down too.
