4wd axle under a 2wd truck?
Ocala
K-5
As I don't have both my truck with me today, I'm gonna ask here.
I have a rear axle from a 91 K5 that I scrapped. It has a 3:42 gear with a G80 locker. Now my 84 GMC, according to the RPO has a "standard" rear gear, assuming 2:73.
Am I correct to assume it's a no brainer swap?
Or am I missing something?
Thanks
The 4x4 axle housing should have slightly shorter shock mounts and it has a 6-lug wheel bolt pattern. But yeah, it bolts right in.
Ocala
K-5
Yep, I remembered the bolt pattern after I posted.
mattsk8
Michigan
I'd still look into it. I'm not sure, but possibly someone here would know... assuming both diffs are the same (guessing a 10 bolt) can't you take the 5 stud axles out of your 2wd diff and put them in the 4wd diff??
It's a direct swap, EXCEPT in '88-ish, the axles went from 28 spline to 30 spline.
sqlsucks
