Slooptin
- Mar 6, 2017
- Houston
- Vance
- k30
So, I just started having this issue today. Engine is a 454 (stock internals/stock q jet) set at 8* BTDC @ idle (~800 rpm). Sitting at ~19 inHg at idle, mixture screws are about 2 turns out from bottom. The engine only does this after running for a couple minutes (I drive it around the block to replicate) and when I **** it down, it sounds like it diesels for a second and then kicks back air/fuel out of the intake, opening the secondaries. I haven't had this issue at all until today, and no matter what I change (idle speed, timing, mixture) it still happens to different degrees. Can anyone point me in the right direction?
