454 engine oil cooler housing leak
Coldercorgi6637
Memphis, New York
Cheyenne Super C20
On my 73 c20 camper special, and the 454, the engine oil cooler filter housing is leaking above the oil filter. I could use some help finding a gasket for the housing to the engine block, or if anyone has info on where I can buy a non cooling filter housing with a gasket. Thanks in advance!
nvrenuf
Mobile, Al.
Felpro used to make a gasket kit for the oil cooler adapter.
If you remove that adapter the filter adapter from an SBC or BBC will work.
Rusty Nail
Rusty
350sbc
I wouldn't remove it. You can buy generic trim to fit gasket material that is cut-to-fit ,if you have too much trouble sourcing the correct part - taking it off would be my absolute. last. resort. and even then I would try not to.
fast 99
Spokane, Washington
Correct kit, napa also has them if thats easier. Have resealed countless of them. Only hard part is the smaller gasket in the block recess. Sometimes they are really stuck. I use an air tool to buff it off. Just be sure to rinse all the old material out.
And of course oil will be dripping on you unless adapter is removed a day ahead.
edit, if you're really intent on removing the cooler all that is needed is a non oil cooler casting, almost every big or small V8 or 4.3 V6 has one. Should be easy to locate.
85K304SPD
Las Cruces, NM
Richard
Any parts store, Ebay, amazon. The gasket kits are readily available. I bought one for my K30 recently, from one of them. No reason to eliminate the oil cooler if it just needs a gasket.
c20suburban
