19gmc84
- Nov 12, 2013
- Virginia
- Norman
Oil pan gasket? Oil sending sensor up top ? Rear intake manifold leak although that should just be a little dribble.
This engine although not new...we put in just recently...engine was powerwashed and painted before we put in so any oil leak should be noticeable...I've checked all over the engine...no oil pan gasket leak before and new one was put in after main seal replacement, oil sending sensor should be up by distributor right? No oil there...don't see any coming from manifold either...or valve gaskets, could be missing it...but don't think so.
So anyway...maybe it's starting to seal it self up...after driving it a few times...I see oil...but dipstick shows I've lost just a tad bit of oil...maybe the oil spreading is making it look worse than it really? I was told I had to drive it and it would hopefully start sealing up...is this true? I expected it to leak a little anyway...just because the two piece is crappy design, was just hoping it wouldn't leak as bad.
