3 speed to 5speed
CSFJ
I'll sell the "4 speed" or give it away im not sure if it a a very popular tranny and have to save up and go tremec
They're still a popular trans with the right group. The sm465 has a rep as being virtually bullit proof, and was found behind almost any engine gm put in these trucks. Pricing kinda depends on demand in your area though. They tend to be somewhat common, so that holds it down. The last one I picked up, I got for $50. And that was a later 32 spline output 4x4 unit. I sold the 2wd sm465 I had for $50 too. On the other hand, I've seen them listed for $150 before, so it's kinda wide open on resale value.
roundhouse
atlanta ga
justin
77,78,79,80 ?
Shouldn’t be too hard to find a NV3500 from a 97-07 2wd Silverado
I recently swapped in a 3500 to replace the SM465 four speed
Mine was 4wd so harder to find
And Chevy didn’t put the 3500 behind the 5.3 only behind the 4.8 but it’s held up fine behind a 5.3 with 35” tires and a teenage boy driving it
And it’s a blast to bang thru the gears
We ran it with the old 350 for a while then swapped in an LS 5.3
Think we used the existing crossmsmber and mount from the four speed
Your biggest job is going to be the hydraulic clutch
I used a stock square body mc and used all thread to mount it to the firewall so I had some adjustment and I just drilled a hole in the clutch pedal and bolted the mc rod to the pedal
I bought a new slave throw out and had a local hydraulics shop make the hose
They cut off the weird connector on the slave and welded on a threaded connector they had in stock and made a flex hose to run to the mc
If your clutch pedal pivot up top is worn out behind a bushing repair
I discovered that the brake pedal from an automatic will work if you cut off the bottom of the pedal and discard it and flip
Over the top half
Then bolt the bottom half of your old clutch pedal to the flipped over top half of the automatic brake pedal
Also when you are mounting the mc
Cut the large hole first and get it where you want it and then use the mc mounting holes as a guide for drilling the bolt holes in the firewall
Don’t try to drill all three holes at once
Douglas Williams
Mountain Home Idaho
Douglas
Dam that does sound like a bit of work but if I want more then 3 gears I guess I have to put on the work
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
they are still very popular for offroad and rock crawling. the low gears are great for it. btw I have the same 350, sm465 granny 4spd combo you have. Id love overdrive but I dig it as is.
Douglas Williams
Mountain Home Idaho
Douglas
Im ok with it for now but the highway speeds here are 80mph and 4 years and gonna cut it when it becomes summer
roundhouse
atlanta ga
justin
77,78,79,80 ?
No one has suggested an LS swap yet?
How about a Ranger Overdrive?
roundhouse
atlanta ga
justin
77,78,79,80 ?
I have the dodge / Jeep version , the NV-3550 in my 74 Bronco
The ratio spread is perfect
The dodge Jeep version was available with a normal mechanical clutch linkage amd a removable bell housing and some places sell adapters to bolt it to ford bell housing
Not sure if anyone sells a adapter to bolt it to a Chevy bell but advance adapters might
malanr
