73c20jim
- Jun 11, 2018
- Tombstone, AZ
- Jim
- C20 2WD Custom Deluxe. C10 2WD Base Model
- 350 CID 195/260 HP Goodwrench crate, 400 CID 2bbl
I had threaded shoulder bolts holes also. One side went fine but the other side, the sheet metal hole did not line up with the threaded hole. so had to Dremel out the sheet metal, so the bolt would go in.
Mine came with a large assortment of mounting brackets and bolts. I needed the HD angle brackets from the assortment to mount the retractor. Both the retractor and the lap belt connected to the angle bracket.
I bought all new Grade 8 bolts washers and lock washers (needed 6 of different sizes) and was able to use all the stock threaded holes in the body.
I reused the middle seat lap belt.
I removed the seat to check the condition of the floor and to make installation easier.
Took two of us to install the seat, but you are probably much younger than I.
If it comes with instructions, read them twice before you start.
When I go out this morning I will take pictures.
Hope I covered it all.
