3/4 ton axles or detroits front and rear?
Swims350
Logan WV
none
it most likely has the axles you want since it's a 1 ton 4x4.
as for lift, no don't add a bunch of springs to your pack, it can be done, but would need a longer centering pin.
just buy some blocks for out back, or add a leafs, even zero rates. for the front you can do zero rates, add a leafs or get some rear springs from a k10, YES REAR springs that are 52 inches long and swap them up front, those add about 4 inches or so of lift up front maybe less, and the same can be done out back with 56 inch springs I think it is, like 3/4 ton or 1 ton leaves that are longer.
both spring swaps require moving the hangers, front requires switching sides.
add a leafs or zero rate require you to unbolt the spring pack and then insert the zero rate or add a leaf on the bottom and then reinstall with new centering pins.
warrpath4x4
Prosser, WA
72 K5/ 79 stepside/ 1989 suburban
that truck should have a dana 60 and a 14BFF, that 14 bolt will have to have the spring perches moved due to frame width changes. the dana 60 mounting wise will be the same, will need a conversion u-joint, but you will need a conversion u-joint for the rear also.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Dont let them crush that truck if it has a Dana 60 on the front. Even if for some crazy ass reason you wouldnt want to run it they are worth big bucks.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
...Now i have to find a mask just to go see lol :doublepuke:
GorillaHumper
