3.08 Gears. What to Swap to?
Normmus
Saskatchewan
Norm
Truck is a 1977 K10 with a stock 350, SM465, 31 inch tires, and 3.08 gears. It sees about 70% highway, 20% in town driving, and 10% low speed yard driving (some deep snow, small hills). No towing at all. I am satisfied with the highway performance, but it feels like it needs deeper gears around town but I can live with it. I want to go up to a 33 inch tire and lift it a bit. I know I will need to regear to be satisfied but for new gears I am having a hard time deciding between 3.73 and 4.11. Wondering if anyone has the same drivetrain as my truck and done a swap to 3.73 or 4.11 and what you liked/didn't like about it.
Edited to add - I do not want to swap a different transmission in.
Get a tach drive your truck note your rpms at different speeds. Then look at an online gear ratio calculator,see how many rpms you will be turning at the speeds you commonly drive at. Go drive your truck at those rpms. Are you comfortable at those rpms? Problem solved.
Redfish
Prairieville, LA
Andrew
V1500
My '87 has the stock TBI 350, SM465, 3:42 gears and 33 inch tires. My motor has a few more horsepower than yours so this isn't apples to apples...
I don't have a tach so I cannot give specifics here but for all around town, backroads, 55 mph two lane highways, my gearing is okay. It still pulls like a tractor in 4 Low and as you know the "L" gear on that SM465 is pretty low. I use this pretty frequently. I have not wished for anything lower or higher, but this truck is not my daily driver either.
Based on your usage I would say 3:73. I think 4:11s on the highway would be annoying with 33 inch tires.
My Truck:
legopnuematic
Licensed Junk Dealer
MO
Spencer
3.42-3.73 I think would be satisfactory for your usage.
With the 6.55:1 first (or low) of the sm465 and if that’s not enough you have low range with the transfer case to get something moving.
Snoots
Roger
Jimmy Sierra
350 w/203
I've got 3.73 but wish I had 3.42. Kinda $$$$ when you have 4WD.
JUKA
