shiftpro
- Aug 31, 2012
- BC Canada
- shiftpro
- 1500, 2500, 3500
- 350, 383, 454, 496!
Which one is the cheaper way to go?
I can't answer that. Depends on a price for 4x4 chassis. If you go with a B52 kit, you still need rear springs. Finding them in a junk yard is a gamblke because good chances they have been worked and are worn or sacked. You would need longer shocks, and good shocks cost more. Shocks are like,
you get what you pay for.
Another big hurdle is to convert to cross-over steering which I'm not convinced is absolutely necessary depending on use. If you rrally want to use the travel and flex afforded with 52" springs, then cross over is the only way to go.
I feel your best bet is to remain patient and vigilant for a cheap 4x4 chassis. I have seen completely rusted out trucks with a good frame and also.. visa versa, good cab and body but frame is a mess.
