87silveradok20
- Jun 29, 2014
- Ohio
- Levi
- Silverado k20
So I picked up a 1984 c30 with a 12 valve cummins for next to nothing last night. At the same time I picked up a Dana 60 front axle. So as you can imagine I want to put the axle under the truck. I was thinking of doing the b52 front spring hangers from DIY4X then the factory hangers in the back(drill holes and attach). Does this sound doable? Also what size spring pack will I need to hold the weight of the cummins? For steering I was going to use crossover steering. I have no idea what the best way for this set up is, so could someone point me in the right direction there. Pictures of the truck will come as soon as I go back to pick it up.. And those of you who have seen the k20 build thread and are wondering if it will be replaced. the answer is no, this will be the daily and the k20 will be the nice truck. (I know I need to update the build thread on the k20, im planning on doing that after i get it back from the body shop).
