2 piece driveline
Bigred3plus3
Washington
Kyle
V3500
I have a question. Are the 2 piece drivelines keyed? Like do they only clock one way into the yoke at the carrier bearing?
Sent from my SM-G970U using Tapatalk
Poppy 87
Bloomingdale GA
R10 Silverado
If memory serves, I think that there is a master spline.
Sent from my XT1254 using Tapatalk
Bigred3plus3
Washington
Kyle
V3500
Kinda what I was thinking.
Ok, I'm curious now. Why were you asking?
Bigred3plus3
Washington
Kyle
V3500
I might have a phasing issue. I'm getting a driveline vibration. But need to replace carrier bearing first.
Turbo4whl
Downingtown, PA
Wayne
Some are keyed, most are not. The slip yoke will be missing one spline, but the front drive shaft spline will not have the one wide spline, so it can be assembled wrong.
Bigred3plus3
Washington
Kyle
V3500
You know I put it together about a month ago but for the life of me I can't remember. I was in a hurry to get it bolted on cause the wife was needed my help so I was kinda rushing.
Even if it only goes on one way (which I believe that's true), it's possible that the shaft could be 180* out of phase if the center u-joint was changed and the shaft not put back the same.
Bigred3plus3
Washington
Kyle
V3500
Yeah its Definitely possible.
goodwrenchca
