2 inch Rough Country Lift 76 K10
Redfish
Prairieville, LA
Andrew
V1500
I did go with the 33x12.50r15 bf goodrich A/T's with the raised white letters. And after looking at your truck and Redfish's, I think I will definitely be ordering skyjacker 2.5. I am still debating if I will do rear springs or just do the blocks. You guys seem happy with the rear blocks??.
I had a very specific reason for staying with the blocks. The SoftRide springs would have made my truck ride better but I would have lost some carrying capacity.
It was not about the money, although the rear springs are a lot more expensive than blocks.
I use my truck as a truck from time to time. Yes, it is mostly a play toy but one of the things I love about it is that it can carry a lot of weight without doing a "Carolina Squat". Keeping the stiff factory springs lets me keep one of my favorite things about these trucks.
antique_jdfan
Tn
Michael
Thanks for the reply and all the good information (i like details). I think I'll order the kit with rear blocks. A person could always change springs later.
Looks like skyjacker "requires" the drop pitman arm, but I have never used one on a square with less than 4". Are yall running factory pitman arm?
Redfish
Prairieville, LA
Andrew
V1500
I am running the factory pitman arm. Since I removed one leaf from the front stack of springs and my lift is actually about 2" my pitman arm is still pretty much level. I thought/think that a drop arm is not required until you get around 4" of lift. But I could be wrong.
antique_jdfan
Tn
Michael
I have always thought there was no steering correction needed until 4". I just noticed this when I was looking up the kit on skyjacker.com. I have had 2-3 lifts on other trucks with no issues, so I think I'll go with my stock pitman arm. Thanks again
GorillaHumper
