- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
I love clearance lights, but that truck was definitely special ordered as they look weird on a little 1/2 ton 2wd.
Nice truck. For sure. Are you trying to flip it or just see if you got a deal on it?
Apparently values vary ALOT around the country, although I think the $2-3k guys are are low by a couple grand. Although it's hard to put an actual value because it has some serious plusses and minuses in the same equation.
Big plusses, original rust free low miles, looks well cared for, except that it must have sat outside for a LONG time. The super low miles doesn't bring alot to the table as at 34 years old, EVERYTHING mechanical is suspect or possibly needs replaced. Especially considering it appears that it sat untouched for years. But you would know better. No leaks, doesn't burn oil brakes and front end great, trans works like it should, or sticky brakes, only 2 oil leaks and a rotten radiator and ATF is brown. 2 different scenarios.
Biggest detractor is probably the paint. Decent paint job is a few grand minimum or alot of time and still 4 figures worth of materials.
Next is interior and trim. Looks pretty good, but if the dash and seat are crispy and the other little things it needs like emblems restored etc. Theres another $1000 in look good parts.
To the right buyer, I'd say $4-5k based on the low miles if everything else checks out.
Short bed helps the value as does V8/auto drivetrain.
Either way cool truck and welcome!
