1986 roll over oil switch
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
in 1986 did chevy put a roll over oil switch in c10 the v 6 I pulled out had 2 oil psi sensors in it 1 has one green wire to it the other has 3 wires to it pink ,blue hard wired into the harness the other is green and has a conector on it where dose that wire go it was not hooked up when I unwired the v6 I am at a lost
One was for the gauge, the other (3 wires) was tied into the choke circuit.
But IIRC, a green wire is usually engine temp or AC clutch power. That connector doesn't look right for an oil sender.
74propu
florida
austin
5.3 / ?/454 tbi
ok that make sense the choke was not hooked up and that wire was just laying on the eng . so can I just do away with the 3 wire oil sender don't need a choke on a BB tbi engine
jimlayhee
