1986 K10 Silverado
one4fun
Portland, oregon
chris
1986 Chevy K10 Silverado - Short Bed
350 V8
Oil changes done every 3,000 miles since I have owned it.
Quadrajet carburetor
700R4 transmission - Total rebuild and upgraded all in November 2013, including a Transgo shift kit (by Tim at Beaverton Transmission)
NP208 transfer case. 4WD works beautifully.
New power steering pump.
New Steering gear box.
Jeep steering shaft conversion.
Dual Rancho steering stabilizers.
New tie rod ends on Pitman arm and left steering arm.
New starter and battery installed in 2014.
GM 10 bolt with 3.73 gears.
33x12.50x15 BFG All Terrain TA KO (driven 27K miles)
Spare is also BRAND NEW 33x12.50x15 BFG All Terrain TA KO mounted on steel wheel. Spare tire has a Bestop tire cover and is mounted in the bed.
Warn 8274 Winch with cover. Winch controls are wired to allow driver to operate from inside the vehicle. Also has original Warn wired remote for operation outside the truck.
Rancho 9000 adjustable shocks with 4" lift
Warn manual locking hubs.
New custom built rear driveshaft and u-joints. (build by Driveline services of Portland)
Bully steps - black
Body is straight and in good condition. Paint is weathered down to visible primer on part of the hood.
Very nice and clean interior.
Power windows, Power door locks.
Sliding rear window.
Bed rail guards - diamond plate.
Custom built headache rack.
Custom built brackets for holding a Hi-Lift jack.
2 15.5 gallon fuel tanks - one on each side with matched key locking caps.
Welded hitch below rear chrome bumper.
Wired with flat 4 prong harness for trailer lights.
K&N air filter.
Doug Thorley stainless steel headers.
Sony head unit
2 - 6x9 speakers and 1 - 12" subwoofer behind the seat. Amp under the seat. Nice sounding system.
Headlights were upgraded (including headlight wiring harness). Now uses 2 - relays to power H4 headlights. Includes 80/100W bulbs and ceramic headlight connectors.
Clean dash, working gauges, runs great.
Has factory cruise control and air conditioning. Neither were working when I purchased the truck. All components appear to be present.
The clear coat is flaking off. I believe the motor to be all original. I has been my daily driver for the last 2 years. Mileage on the odometer is 14,***.
Clean title in hand, tags valid until December 2015. (passed DEQ on first trip thru in 2013 without any issues)
I also have receipts from the previous owner for services that were done on the truck.
includes original Chevy shop manual, wiring and vacuum diagrams.
Asking $4150.00 - Located in Portland, Oregon.
No trades. Will not part out.
PM me if interested.
sparky77
