scenic760
- Jan 12, 2021
- SoCal
- Chris
- Suburban K10
Hey All,
Trying to get everything hooked up to fire this thing up and break it in but trying to figure out what exactly needs to be hooked up since I ditched the carb and installed an MSD Atomic EFI, also the 6AL box, distributor and coil which are all CARB approved... In the process of doing that, I ran across some threads and schematics suggesting that maybe this had some sort of ECM or spark control box/wiring at some point.
In previous post I have noticed that 1981 was a weird year for emission stuff and in that California cars, different engines, vehicle weight, build dates, etc.. would give you different results...to complicate it even further I've also read somewhere that Suburbans were different than trucks?!?!
The engine compartment sticker has it as a California Emissions model...however there does not appear to be any mention of n ECM or spark control on the diagram..that and there is no harness on the firewall, I took a look under the glovebox and there is no module or space for one that I can see....
Alll that being said, I have a connector I don't know where it goes and one of the wires is broken...so I have a three part question I guess:
1. Anyone know what connector that is and what the three wires are?
2. Is it possible I have an 1981 Suburban with no electronic module or more likely the previous owner did a fairly complete job of ripping everything out?
3. Looking at the emissions label, the year part of course is worn off! But there is a part number in the lower left..is that the sticker part number? If I had to fill in the blanks I would say it says it says "model year 1981 new medium-duty vehicles"?
The only issue I'm concerned about is passing smog...THANKS!
