1980 K20 Rear Diff fuild
Nottle
Saylorsburg
Hey guys;
I have a 1980 K20 with a 14 bolt rear. The rear diff cover is leaking a bit, since the truck is new to me figured I would pull the cover and check her out.
The question is what type of gear oil are you guys running (weight and brand) and amount? From what I can tell it calls for 80w-90 and about 3 1/2 quarts.
If it matter I live in PA so it does get below zero sometimes in the winter.
legopnuematic
Licensed Junk Dealer
MO
Spencer
80-90, API GL-5 is good. Brand (in my opinion) is not too important. I’ve used mystic, pennzoil, valvoline, castrol, Lucas, harvest king, etc.
I’d recommend getting a 2 gallon jug, that way you have enough to service both front and rear differentials and should be a little cheaper than buying quarts.
Nottle
Saylorsburg
If i use standard Valvoline 80w-90 should I add a friction modifer?
Thanks in advance for the help guys. (and maybe girls)
legopnuematic
MO
Spencer
If you have a limited slip yes, if it’s an open differential no.
dsteelejr
Hudson, WY
I run 80-90 in my ‘80 K25 14BFF when it had an open diff and after installing a Detroit locker. I live in Wyoming and temps easily get to -30°F I in winter and haven’t had issues. Works fine.
Nottle
Saylorsburg
Looks like its a 14bolt FF G80.
Im going to grab a bottle of the Yukon Friction Modifier.
legopnuematic
MO
Spencer
If it is a limited slip, you may need two bottles of Yukon additive.
I believe they recommend 1 bottle for 2qts, over 2qts may require an additional bottle.
It may be fine with one, or clutches might chatter with only one.
Orangepumpkin
