1979 K20 Speedometer Question
Project79
Hector, Minnesota
Cody
Can anyone tell the name and function of this? I'm assuming it is for the speedometer cable but i have no idea what it does or how it works.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I'm only guessing, but my first guess would be cruise control.
WFO
Texas Panhandle
Yeah, that's cruise control.
Project79
Hector, Minnesota
Cody
Thanks guys. I appreciate it. My speedometer isnt working, trying to figure out what it is that is causing it.
mrburitto
Casa Grande, AZ
Cody
K20 Cheyenne Camper Special, C30 Crew Cab Dualy
Same truck and issue. I am planning on looking into it tomorrow. Ill let you know what I find.
Its the cruise control servo. One cable goes from the transfer case to the servo, and then a 2nd cable from the servo to the speedometer. You could get a non-cruise cable and just connect it directly from your transfer case to the speedometer. I found one for my '75 K20 at Autozone for about $18. However, its a PIA to get it connected up to the back of the speedometer.
1. I would unscrew the cable that runs from the servo to the speedometer (the one running over the firewall), and chuck the end into a drill. If you can spin it with a drill and get the speedometer to work, then the problem is lower in the system. IIRC, I think you have to run the drill in reverse.
2. If speedometer worked in step 1, then put the upper cable back on the servo and disconnect the cable at the transfer case. Do the same drill test to determine if that cable is good.
3. If the first two steps work, you have to fix the connection at the transfer case. The speedometer gears are plastic or nylon, and available from most parts places.
idahovette
Weiser Idaho
Perry
K20-K10
If it's a 4wd ,the gear is in the T-case and it could be a metal driven gear
cahillasher76
