1978 c10 rear flip kit question
1sik78
Sparks,Nevada
Manuel
C10 pickup
250 inline 6
Looking to get a flip kit for my truck. I have seen two different styles and I am wondering if one is better than the other? It looks like the rounded one would fit around the axle better and keep it snug but I don't know never done a flip before.
J Knight
Baytown TX
82 Chevy
350ci
The one on top is way better. The flip bracket is gusseted and has a u-bolt plate that has additional holes for the leaf spring center pin to keep the u-bolts better aligned.
1sik78
Sparks,Nevada
Manuel
C10 pickup
250 inline 6
Ok thanks by top you mean the first pic right? One of amazon
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I used the second pic on my 85
I had to cut a hole in my stock u bolt plate for the center pin
if I was to do it again I would buy some perches and weld them on
1sik78
Sparks,Nevada
Manuel
C10 pickup
250 inline 6
Thanks I'm going with the first one, but you still got around a 5" to a 6" drop right?
J Knight
Baytown TX
82 Chevy
350ci
The difference in a 5in to a 6in drop is the spring thickness, its the same drop wether you use a flip bracket or new spring perch.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
here is the truck after I did it
1sik78
Sparks,Nevada
Manuel
C10 pickup
250 inline 6
Question totally off topic here where did you get that bed cover I would prefer a fiber glass one but a leather one would be ok too. Nice truck and looking good. Thanks for the pics too
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
a buddy of mine got it used and made it fit a square short bed by using 2x2 aluminum angle to space between the bed and the cover. in this pic you can see the 2x2 angle the cover is screwed under it you can see the screws in the middle of the 2x2 angle piece
he has no idea what it originally was on
it is almost the perfect length so I have thought about measuring a few newer trucks until I find the right length and a close enough width and get a cover that fits what ever it was
1sik78
Sparks,Nevada
Manuel
C10 pickup
250 inline 6
Thanks I'll be on the look out for a cover now
thom9719
