- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Yep, find you a replacement 73-80 hood. I'd install the braces for prevention purposes since this is common. As mentioned, it's caused by still hood hinges, so clean and lube the hood hinges real good, and keep them lubed. Like maybe everytime you change your engine oil, maybe a few drops of the used motor oil at the pivot points of the hood hinge.
Yours actually doesn't look bent real bad yet. That tip @Lastwords suggested may work to get it at least real close then add the hood braces or something equivelant that you might be able to make yourself.
