15" rims on a k20 suburban
Powderbullet
Ms
Norm
K20 Suburban
I recently bought a set of 15" buckshot q mud grips that are mounted on 5 x 5.5 rims. My K20 has an eight lug hub on 6.5-in spacing. What's the best way to get them together? I don't use this vehicle on the road - it is strictly a hunting truck. Apparently no one makes an adapter to go from an 8 lug hub to a 5 hole rim. I don't think anyone makes an eight lug 15-in rim either. Is my only option to custom build a rim? If I do will I have issues fitting 15-in rims over my hub and calipers? I wouldn't make such a big deal about it but they quit making these tires about 10 or 15 years ago and I consider myself lucky to have found them in any size. Just hope I can make them work!
rpcraft
Robert
LS 6.0 364 CID
My understanding is there will be some fitment issue on the front brakes because the k20 front brake calipers are slightly larger diameter than the 6 lug counterpart. I think you can shave the brake calipers and then have the 15 inch wheels fit (and there are reportedly no ill effects).
Powderbullet
Ms
Norm
K20 Suburban
Okay I love this forum already. Thanks for that! I have spent a good bit of time looking for exactly that but evidently I'm not as good at it as you are.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Probably would need to do something to this affect. Thats on a dana 60.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Is that ground for clearance? Hah, I love it
Vbb199
Salisbury NC
Vince
rpcraft
Robert
LS 6.0 364 CID
Yes but keep in mind the front on a k20 is still the corporate 10 bolt usually but the calipers are mounted to a backing plate that still has a larger diameter. I'm not sure why they do that but the difference is 11.86" vs 12.5" inches. Not sure how much of that turns into the grind on the calipers but it might be dependent on the wheel too. I'd say a steel stock, Wagon or D hole type wheel may be thinner than a spun or forged aluminum so that may be the difference. I've kind of been wondering my own self what would need to be done overall.
rpcraft
Robert
LS 6.0 364 CID
I mean, *i* wouldnt do that ****...
I have 16.5" rims on my dana 60 lol
are 16.5's the ones that for the factory steel wheels they didn't have the safety bead for keeping the tire from debeading?
Craig 85
Nashville, TN
454/TH-400/NP205
Correct. I had a valve stem crack on me and the tire deflated. The outer bead slid right off. Luckily the truck was parted when it happened. Here's what the bead looks like on a 16.5" wheel.
rpcraft
Robert
LS 6.0 364 CID
Yeah I had a chance to set up a set of mint polshed 5 slots (like the MT challengers) but they were in 16.5 and I decided it was not worth it in my world. I have some old aluminum wheels from the 80's era on there now and I'm probably just going to powder coat them something dark, if I choose not to go with stealth black.
TubeTruck
East TN
Denis
Suburban K10
LQ9
OK I will ask. WHY? highdesertranger
Running a 15" wheel gives you more sidewall and better tire deflection over terrain when aired down.
There are companies that make 15" 8 lug wheels, Bart being one of them. Grinding down the caliper on a D60 you need to remove 1/2" of material from the front half of the top of the caliper. This is no way compromises the integrity of the caliper. No idea why they made them so thick but I've never heard of one failing that was ground down but I'm sure you wouldn't be able to use them for a core in the future, lol. I'm not sure if you have to do the same on a 3/4 ton axle. Check FB Marketplace also. I've seen a few sets in the Midwest for sale.
Kiely
Michigan- Wyandotte
C10 Custom Deluxe
454-4bbl
There are companies the make adapters. The thumbnail below showed one such company
agent_mattman
