10W-40 for Chevy 350
Baker11b
San Antonio, Texas
Alexander
I've been getting a little bit of blue smoke on startup. I'm thinking of going with a thicker oil. I'm running 10w30 conventional now. What's the minimum temperature I should run a 350 with 10w40? We're talking Texas Winters. Think the coldest it ever got here was 11 degress F.
78C10BigTen
pennsylvannia
C10 BIG TEN
Run it year round. I am not sure that will help with your blue smoke problem though. That would probably be oil getting past the seals on the valve guides. How many miles on the engine?
I agree! I run 10-40 in all my vehicles.
Baker11b
San Antonio, Texas
Alexander
Idk. It was swapped at some point. The heads look new. Probably an early tbi model because I found a matching alternator under by searching under a 1988 K1500. Is there any reason I shouldn't use 10w40, though? Kinda irked about upping the weight.
85K304SPD
Las Cruces, NM
Richard
There is no reason that I know of not to run it. I prefer to run 20w50 in my old engines. What is your concern about running 10w40?
Baker11b
San Antonio, Texas
Alexander
Because Chevy says to use 10w30 lol. It actually smokes a lot less on startup now. There's still some but a lot less.
Trucksareforwork
Spartanburg SC
Geoff
Valve seals. I just did mine in my 85 305. Made a world of difference in both smoke at startup and smoke at idle (my guess is vacuum was pulling oil in past the intake seal).
With a spring compressor and an air compressor with a spark plug adapter to pressurize the cylinders, it took me about 5 hours, probably an hour to do the first couple then the balance for the other 14 once I got the hang of it. I posted on this a couple months ago. Well worth the effort and the parts are cheap.
“Thicker oil” still burns.
ChuckN
Bellinham, WA
Chad
My 350 is an almost new rebuild (~1000 miles). I started with 10w-40 with Lucas ZDDP additive during break in and since have gone to Valvoline 20w50 VR1 for the flat tappets for warm weather.
The other day it was 30-40 degrees- it cranked a tiny bit slower, but otherwise I don’t see a downside. It doesn’t irk me at all to run a thicker oil.
Buck69
Northern British Columbia
D30 CUCV
6.2 (removed)
10/30 and 10/40 both have the same cold start viscosity rating.
I would not be concerned with increasing the viscosity slightly. Watch your oil pressure. Too high, adds additional strain to the cam gear and pump drive.
Look at a marine 350. Internals are the exact same as what's in an auto with the exception of a milder cam and the head gasket composition. They recommend 20/50 for that application.
Marine engines are under continuous load and do not get above 160 F. I cannot bring myself to paying $20/ltr for the 20/50 though. Have tried 10/30 in them and they tend to burn a little bit. With 15/40, they don't. Have been running it for years without any issues. Lots of boaters do with these engines.
Auburn, Washington
Castrol 20-50 is dirt cheap. Has been for a while. Not good or necessary for a tight new engine IMO or anything less than warm weather but it’ll run fine in a small block or a LS.
Auburn, Washington
My 4.3 and LS motors all get 15w-40 diesel oil.
Virtually all the 4s engines I have or had, from mowers and dirt bikes to small/big blocks, LS and newer Hemis ALL get 15-40 and run just fine.
Except in extreme cold, which isn’t an issue for me except the truck and snowbike occasionally. Bike gets T6 5-40 (wet clutch safe, jaso MA rated) and the truck gets 5-40 or lower when we was in AK or CO mtns.
Although I did see a super sale on 10-30 syn Napa brand a couple months ago and stocked up on it for some of the engines next service.
Jimc21NC
