lusktommy
- Jul 17, 2012
- Tuscola, TX
- Tommy
- C10
- 5.7L (350ci)
That's not even close to a streetable motor. That without doubt is nothing less than a trailered to the track bracket race motor. Keep in mind, anyone can bolt a motor together. But not everyone can design one to stay together. Red line as in that's where you'll float the valves or red line as in that's what will hold together? And you're putting all this in a Stroker 383 and think it'll turn 8500? Any idea what the Static Compression ratio will be on this motor? Pump Gas? Dynamic Compression Ratio? Is this cam, roller, sold or hydraulic? Not sure if you're doing research or just listening to people that you THINK know what they're talking about, but alot more work that not you're not mentioning here needs to be done to build this kind of motor. If I was your machinist, I'd tell you all this **** too. This way you'll be back once a week having a motor built and keep me busy. As said, anyone can bolt a motor together with parts and big cams, and impressive sticking out of the hood tunnel rams, but will it run good? Will it hold together?
the redline is what it had been balance to and that is what it can stand, now i will not be reving that high 7500 is where im gonna be shifting at. and i say that my intake is advertised from 3000-8000rpm power band. so thats what i try to stick between. and The Compression is gonna close to 12:1 maybe a little higher and i might be wrong if so correct me, and no pump gas is out of the question i buy race gas for track and additives for street and she will be running the street too not just the track and i guess you will see how good it runs when im done with it and take it to Pine Valley Raceway in Dibol, Texas and video the passes i make. i have buil high performance motor before to go in a 1968 Camaro started from scratch on a 502 big block and that was my learning experience of building and setting up performance motors i have a good friend that is part owner in Mast Motorsport here in Nacogdoches, Texas and all they do is build wicked engines and beef up cars and trucks. and yes i havent went into all the details and things i have had done just to build the bottom end the proper way to be able to stand extreme abuse. and if i need to lower the compression some plz let me know the RHS heads im getting are coming from a friend that didnt need them anymore so if need bigger chamber heads or flat top pistons im open to all recs on this. but the flow from those head will be phenomenal i think so id much rather change pistons than heads
