beady
- Jul 20, 2024
- Tidewater/Northern Neck VA
- Mine
- R20
Drove the truck for an hour to pick up my kids Sunday. Turned truck off, kids put their stuff in, daughter went to start truck literally 2 mins after I turned it off and it would crank fine, but not a hint of fire. Ended up having to get it towed home.
There is ZERO fuel from the injectors when cranking and the tips are bone dry. There is 10+ psig of fuel pressure downstream of the fuel filter and you can hear the pump running in the tank.
There is +12v at one pin of each injector connector with the key ON.
There is NO pulse from the injector wires (using a timing light clipped to leads).
There IS spark at the spark plug wires.
Ecm B fuse looks fine.
What do I check next?
Thanks
Thanks
