legopnuematic
Licensed Junk Dealer
MO
Spencer
@Chris64 you did bypass/eliminate the resistor wire and give the HEI a good solid 12v right?
That’s something that is often overlooked doing an HEI upgrade, they will work being under volted for a while, but issues will arise at some point.
1976dully
Kansas City MO
C30
Got 6 new tires for the '76. Painful, but they'll probably outlast me. Lol
Got the new offering from Cooper. Stronghold AT 10 plies
WesN
Edmonton Alberta Canada
Wes
C1500
Installed a shifter by using 1” tubing bolted to seat frame so not to put holes in my new carpet. Extra long cable so it goes through firewall. Two bolts and undo cable and it can be removed leaving the cab stock. I race the truck in the NHRA Sportsman class so that is why the shifter, column shift with no safety stops for hitting neutral or reverse was a concern.
Strick
Dunn, NC
Harold
C20 Crew
Well, it is black now. Didnt come.out as good as I had hoped but better than it was. Hopefully nothing a whole lot more damn sanding can fix
I worked on my '87 & it's not perfect but it's good! Considering it was almost 40 years old with mostly original paint, I've given the next owner a much better guide coat than what I started with.
Your ride looks great, put the adornments back on & go ride!
HS
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
I did do the sanding/wet sanding today. Rubbing compound and polish next. This chit is for a much younger person. Following this guy's plan from the SPI forum (mostly)
Blazerlady
MI
Andrea
K5 Blazer
5.3 converted
Oil pressure sending unit in my blazer, oil pressure gauge was not reading well. Did oil pressure test which I did have and the sending unit was bad, the 5.3. Did notice an oil leak too coming from it
Phillippio
Tucson
Greg
C15
Nice long weekend to put in a Edelbrock Performer intake and general top half clean up. I also replaced a leaking freeze plug. NOT Fun. Not hard, just very difficult to get to. I have to get the rest done since one failed.
She runs well. Timing set to 10 degrees BTDC. New tach will be here Wednesday to help set the carb.
Next in line is fuel tank replacement. The PO included a new tank and sending unit. It would be nice to know how much gas I have in the tank. I can get rid of the jug I have been carrying around for when I run out.
When warm she only has around 15 psi of oil pressure at idle, jumps to 30 by the time I hit 800 to 1k RPM. Then nudges higher with more RPMs.
brooksman9
Olive Branch, MS
Patrick
350 & 305
Not horrible but I'm not going to win any Good Guys awards either. Kind of resembles the way they came from the factory. Only this front corner is polished so far.
8
Chris64
San Diego
:oops: I sure did...err...tonight.
So that line going to the coil isn't 12v? TIL.
legopnuematic
MO
Spencer
On a 1973-1974 (or 1975 with Electronic ignition delete, so points) they use a resistor wire that with key on drops the voltage to ~7-9 volts to keep the points from burning up. They also use the post on the starter to provide 12V to the coil to bypass the resistor wire when cranking.
Basically serves the same purpose as the ceramic ballast resistors found on Chryslers.
If you search the forum you should find some discussions on removing the resistance wire and feeding the HEI the 12v it wants.
Chris64
San Diego
I tried to find a good thread on best practices to remove the resistor wire and replace it in the wire harness etc but I need a tach wire run anyway so I'll just run two new wires (one for Tach) and just cap the resistor wire to off in the wire loom. Thanks for warning me about that.
Spider
Montana
gmc v2500 sub
5.7 tbi
Drilled and installed a t stat, Installed a retro sound stereo, one lmc headlight (they made it sound like a set), noticed the entire ac bracket was loose, removed it and the water pump, tapped out a broken bolt in the head, reinstalled said parts and made another list.
Edelbrock
Earth
Grumba
K5 Blazer
There have been 4,668 days since July 11, 2012. That's when this topic started.
So if your kid was born at that time, he/she would be..... 13.
And if you bought a new car at that time, then its overdue for that first oil change.
And if you had purchased a new bottle of Scotch at that time, then its ready to enjoy.
Oh, and if you are reading this, then you should grab a beer and say cheers!
slo30
