TheC5Surgeon
- Aug 2, 2021
- Panhandle of FL
- Matthew
- C20
Heard a clinking noise while running around testing the new build/motor. I think the culprit is the dust guard moving around that I put on the new carrier bearing I installed. Not sure If I was supposed to include that but any ideas on how its supposed to be installed? I could maybe epoxy it against the bearing so it stays in place? Also, I noticed after taking these pictures that my bearing is installed in the up orientation rather than upside down like i see in most pictures. Is that a suburban thing or did I screw this up? Pretty sure I installed it the same as I took it out. Plus I believe there is a section of x pipe right underneath that which would make it impossible to install the other way.
