harveymuckraker
- Apr 17, 2025
- Napa
- Andy
- R3500
I just rebuilt the motor in my 1989 R3500 (still a square body) and I'm planning to re-install the A/C system. I was on the fence about this for awhile but decided to go forward since it gets pretty hot where I live.
Here is where I am so far:
I have flushed the condenser and evaporator well. Clean and dry.
Already purchased: new dryer/accum - AC DELCO replacement, pressure cut-off switch
About to purchase: new hoses and lines, new orifice tube, and of course all new o-rings. Lastly - a new compressor.
I have access to R-12 and a guy who can do the filling. I'm told it's better to go this route if one can but then again I'm no expert on this so that's why I'm here.
A. Will all new/reman compressors that are available function properly with R-12? Are some better than others? I am bracketed up for the old Harrison type v-belt (short body) and would like to stay with this configuration unless there is a compelling reason to go with something different.
Will the orifice tube that I purchase as a direct replacement part be configured for R-12? or will these work for both systems?
The hose assembly and accumulator line seem readily available from multiple suppliers. Any best choice advice? Same with o-ring brands.
Lastly, oil. Any brands better than others?
Thank you in advance for your responses.
