Power door lock conversion
Silver Square
Fayetteville, GA
Jason
Sierra Grande 15
My '77 GMC K15 does not have power door locks. I would like to convert it, but the only kits I can find are universal. Is there a kit designed specifically for these trucks that is plug & play with the factory wiring harness and compatible with the stock door switch? If not, are any of the universal kits going to play nice with the stock switch? The keyless entry feature they all offer would be kind of nice. Thanks!
Doppleganger
OH-MI: Just like it sounds
LMC doesn't have anything? I know I have seen the kits that included the factory switches, harness and those goofy OE plug ends.
1STLS1
West Phoenix AZ
MIchael
I bought this universal kit from Dakota Digital because I wanted something from somebody who is reputable. There are kits out there for under $20, I just don't want to deal with figuring it out when it doesn't work anymore. The cost difference is minor compared to the day I would lose trying to figure it out.
If you know a little about writing you could use one of these and use your phone to lock and unlock it.
https://www.amazon.com/dp/B07CZF154L/
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I used G body lock actuators on my 81. The actuator is pretty common, it’s used in S-0, later full sized trucks, vans, big cars, your local junkyard is probably full of them.
Will the door latches from the later trucks fit the earlier doors? If I remember correctly, there is a separate connection point on the latch for the power lock actuator rod.
I would think the doors are similar enough you could adapt the later setup to the earlier doors with a little McGuyverism.
Ken B
indiana
ken
door lock switch question......i need switches for my doors, looking at LMC some switches are 70 bucks for 79-81 trucks 82-87 are 9 bucks,,,anyone know why the price difference? i have suburban doors as replacements looking for switches and since i dont know the year of the doors just wondering how to tell what I need and why the price difference
wheelie-schizes
