Auto wiper lifters to save edge
wooden shoe
kitsap co wa
jon
I drilled a 1/4" hole in these old Tuperware containers, when the wipers reach BDC they ride up on the window gasket and lift the wiper edge off of the window, this prevents them from developing a set and ruining functionality. It should significantly improve wiper life.
Girth
Olympia WA
Garth
V2500 Suburban
I mean.... I just replace them. I see you're in WA too. Definitely a wear part. Never had a set of wipers last more than a year, or at least work well for more than a year, on any vehicle.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Upgrade to the 86 wiper arms. They are a post style and work well. The old "pin style" are terrible.
Not to be an ass but I would never do something like this lol. Will also wear into the glass. It'll rub the grit and dirt and ruin the glass.
SirRobyn0
I've done that upgrade as well. And besides the better wiper connection i guarantee 40 year wiper arm springs are well past worn out.
wooden shoe
kitsap co wa
jon
the "wheel" does not touch the glass, 2.75" a rubber ball would work also.
It looks funky, a single thin wheel would look better and be more aerodynamic.
It doesn't matter which car they are on, the blades fold over and won't flip, then they chatter and won't wipe.
SirRobyn0
Lol what? You know you can take the arms off and adjust them up 1 spline or so to keep them off the gasket, right?
I think I finally understand the principle. It's not that his wipers are hitting the gasket per-say it's that the OP believes that when the wipers are parked the blade edge is pressing against the glass and that the blade's rubber edge takes a "set" from being in that position. So those things he's put on the arms ride up on the gasket and lift the blades off the glass.
I can firmly say though that wiper chatter isn't from the blade edge taking a set, it's because the wiper arm is twisted a tiny bit causing the blade edge to not hit the glass squarely. I have never taken blades off a car and noticed a set in the rubber unless the blades we ancient and the rubber hard. Nothing is going to stop that from happening.
Ohhh I see. Yeah, that's not what's causing the chatter. All blades are designed to sit that way when off, there's no way around it and it doesn't affect their function. I'd say a tweaked arm, weak springs or schmutz on the windshield is what causes the chatter
Bennyt
Surprise
Ben
I knew an old guy that did stuff like this. While we don't understand or "get it", I can tell you the guy was a genius and worked for NASA. He was an airflow engineer and also helped design some of the cylinder heads we have on our cars.
But that was just one guy, the rest of the people I've met do this were batsh*t crazy...
I can appreciate both and thank Wooden for posting his unique take.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Fixing problems that don't exist :rofl: probably batshit lolol.
The confidence is crazy though! Makes an account just to post his Tupperware "hack" lolol.
I think he's suffering from crappy old wiper arms lol. You can see he's got a twist tie on the wiper blade.
Bennyt
Surprise
Ben
Yes, but if you notice the angle of the "tail" of the twist tie, it is placed in a drag position thereby creating down force much like a spoiler. This feature allows increased pressure on the blade for a superior wipe.
ExtraZ
